Applies To | |||
Product(s): | PROJECTWISE DYNAMIC PLOT SERVICE | ||
Version(s): | N\A | ||
Environment: | N\A | ||
Area: | IPLOT | ||
Subarea: | N\A | ||
Original Author: | Beverly Dawn Gentry, Bentley Technical Support Group | ||
What pens can be used with ProjectWise Dynamic Plot?
The pens for Dynamic Plot need to be purchased through Talario (either directly from them via the web or indirectly through us via a PO) and carry with them a license. If you’ll note that when setting up the server you needed to register your pens through the web interface. As part of that process we contact Talario’s server to verify that the pen is licensed through them. The pen that we use is a std Anoto pen DP-201.
