How to load Survey Points in Cogo
Product(s):Bentley GEOPAK Civil Engineering Suite
Version(s):08.11.07.615
Environment: N/A
Area: Survey
Subarea:
Original Author:Nico Roman, Bentley Technical Support Group
Problem Description
User cannot see the survey points in cogo
Steps to Resolve
  1. open microstation
  2. open survey with your project selected
  3. go to survey preferences
  4. Dataset > configuration
  5. toggle on the option to Scan GPK for orphan datasets
  6. select the gpk in your Project Preferences
  7. go to the Dataset Pulldown and create a new empty dataset
  8. your points should now show in the cogo navigator
