| Product(s): | PROJECTWISE INTERPLOT ORGANIZER | ||
| Version(s): | N\A | ||
| Area: | IPLOT | ||
| Subarea: | N\A | ||
| Original Author: | Beverly Dawn Gentry, Bentley Technical Support Group | ||
What does IPLOT_PROJECTWISE_INTEGRATION = true mean?
This variable basically shuts off projectwise processes during plot processing -- i.e. there is no login to PW, the titleblock will not be processed, the components will not process, and the PW pathname will not be used for character substitution.
The variable only affects plot processing. If you open Organizer and login to PW using File - PW Login, the rest of organizer still works fine in ProjectWise mode. I.e. you can still pick files from ProjectWise and save files back into PW, and the PW GUID stuff is still working. This variable does not affect Organizer IPARM creation.
