| Product(s): | PROJECTWISE INTERPLOT ORGANIZER | ||
| Version(s): | N\A | ||
| Area: | IPLOT | ||
| Subarea: | N\A | ||
| Original Author: | Beverly Dawn Gentry, Bentley Technical Support Group | ||
What does the ProjectWise tab control in the Integration menu under the ProjectWise InterPlot Organizer Client Configure Utility mean?
Tthe right mouse button commands in Project Explorer are controlled through the InterPlot Configure integration dialog. These buttons allow you to create a plot set from with ProjectWise
