| Product(s): | ProjectWise Dynamic Composition Server (DCS) | ||
| Version(s): | 08.11.11.xx | ||
| Area: | |||
| Subarea: | |||
| Original Author: | Dawn Gentry, Bentley Technical Support Group | ||
Note: This Wiki also applies to Bentley i-model Composition Server for PDF (iCS).
Getting error: “create rendition. Error code 32768
This error occurs when you have a syntax error in the dmskrnl.cfg file. Check the file for any edits you have made and correct them.
