| Product(s): | Bentley i-model Composition Server | ||
| Version(s): | N\A | ||
| Area: | Installation | ||
| Subarea: | N\A | ||
| Original Author: | Frank Reimann, Bentley Technical Support Group | ||
Note: This Wiki also applies to Bentley i-model Composition Server for PDF (iCS).
ProjectWise Dynamic Composition Server - DCS Configuration Wizard does not finished correctly, it ends with the error message box "Generic Error
A printer must created and the Print Spooler service must running before any dialog DCS Configuration Wizard dialog is starting
