Product(s): | InRoads |
Version(s): | 08.11.09+ |
Area: | Basic Settings |
Original Author: | Jacquelyn Pettus, Bentley Technical Support Group |
Question:
Can InRoads SS2 and SS3 be installed on the same machine?
Answer:
Yes, with the following recommendations:
- Access the softwares using their respective icons. (with either the “-wsLoad_InRoads_SS2” or “-wsLoad_InRoads_SS3” switch set). If this switch had previously been set with a CFG file at the system level, it will have to be removed and set on the icons.
- Use separate MicroStation preferences (username & projectname) while using InRoads SS2 & InRoads SS3.
- Keep SS2 and SS3 datasets separate between the two versions.
