Product(s): | InRoads, MX, GEOPAK |
Version(s): | 08.11.09+ |
Area: | Cross Sections |
Original Author: | Jacquelyn Pettus, Bentley Technical Support Group |
Question:
Is there a way to set the default location for Template Library files (*.itl)?
Answer:
Yes, you can set a MicroStation configuration variable that will define this location:
CIVIL_ROADWAY_TEMPLATE_LIBRARY
