| Product(s): | Bentley i-model Composition Server | ||
| Version(s): | 8.11.11.433 and higher | ||
| Area: | |||
| Subarea: | N\A | ||
| Original Author: | Marion Powell, Bentley Technical Support Group | ||
This video will demonstrate how to use IPLOT settings file when creating PDF renditions in Bentley i-model Composition Server for PDF.
Click the video below to play it. To view in fullscreen mode, first click the YouTube link at the bottom of the video to launch the video on the YouTube site. Then, click the fullscreen button (rightmost button at bottom of video). You may need to set the Quality to a higher resolution in the Settings icon.
