| Product(s): | ProjectWise InterPlot Organizer | ||
| Version(s): | N/A | ||
| Area: | General | ||
| Subarea: | |||
| Original Author: | Frank Reimann, Bentley Technical Support Group | ||
Question:
Can I plot from a newer ProjectWise InterPlot Organizer Version to an older ProjectWise InterPlot Server?
Answer:
No. The ProjectWise InterPlot Server Version must be equal or higher then the ProjectWise InterPlot Organizer Version.
Question:
Can I plot from an old InterPlot Client to a new ProjectWise InterPlot Server?
Answer:
As far as old plot clients (pre-XM) are concerned, they can plot to the new ProjectWise Plot Server.
Question:
Do we have a ProjectWise InterPlot Server Version which is certified for Windows Server 2012?
Answer:
Not at the moment. We do not have a release date at this time. Development is working.
Question:
For which MicroStation Versions can I use the newest ProjectWise InterPlot Organizer 08.11.11.56 Version?
Answer:
You can use the ProjectWise InterPlot Organizer 08.11.11.56 Version from MicroStation J up to the newest MicroStation V8i (SELECETserie 3)
Question:
How is the upgrade path of ProjectWise InterPlot?
Answer:
The upgrade path would be to upgrade ProjectWise InterPlot Server first and then roll out new ProjectWise InterPlot Organizer (clients) as appropriate.
Question:
What licenses do I need for the ProjectWise InterPlot software products?
Answer:
The ProjectWise InterPlot software products including ProjectWise InterPlot Driver Packs are licensed exclusively through SELECTserver XM or V8i. Make sure you have a valid license for your ProjectWise InterPlot products.
ProjectWise Plot Organizer requires a ProjectWise Passport license
Question:
Can I use the old InterPlot Client and Proje tWise InterPlot Organizer on the same computer?
Answer:
No
Question:
Can I use Bentley PowerDraft V8i with ProjectWise InterPlot Organizer V8i in the same way as with MicroStation V8i?
Answer:
Yes
