| Product(s): | Bentley i-Model Composition Server for PDF (iCS) | ||
| Version(s): | 08.11.11.449 | ||
| Area: | |||
| Subarea: | |||
| Original Author: | Dawn Gentry, Bentley Technical Support Group | ||
Note: This Wiki also applies to ProjectWise Dynamic Composition Server for PDF (DCS).
When creating renditions, the InterPlot processor defines a number of ProjectWise properties in the IPS plot properties that can be used for design script text substitution. They will not appear as operating system environment variables in either the iplotorg.exe or ustation.exe processes.
For example, the following logic in a design script will substitute the name of the ProjectWise Explorer submitting user or the PW login name persisted in a stored job, or if not defined, the Windows user name.
if (characters == "$USER") then
envr_var = "RENDSVC_USERNAME"
characters = envr_value
endif
Below is a list of available variables (note that in DCS, these variables start with "DCS_" and in iCS, they start with "RENDSVC_".)
RENDSVC_JOBNAME
RENDSVC_DATASOURCE
RENDSVC_USERNAME
RENDSVC_USERDESC
RENDSVC_USEREMAIL
RENDSVC_DOCID
RENDSVC_DOCNAME
RENDSVC_DOCFILENAME
RENDSVC_DOCDESC
RENDSVC_DOCVERSION
RENDSVC_DOCCREATOR
RENDSVC_DOCUPDATER
RENDSVC_DOCFILEUPDATER
RENDSVC_DOCCREATETIME
RENDSVC_DOCUPDATETIME
RENDSVC_DOCFILEUPDATETIME
RENDSVC_DOCWORKFLOWNAME
RENDSVC_DOCSTATENAME
RENDSVC_VAULTID
RENDSVC_VAULTNAME
RENDSVC_VAULTDESC
RENDSVC_VAULTPATHNAME
RENDSVC_VAULTPATHDESC
RENDSVC_FULLFILEPATHNAME
RENDSVC_ENVPROP_<DocumentEnvironmentName>
RENDSVC_PROJPROP_<RichProjectPropertyName>
Note: When using ProjectWise document environment and rich project properties, if the property contains a space, use an underbar in the variable name.
For example, if the project property is "Project Name", the rendition variable will be RENDSVC_PROJPROP_PROJECT_NAME.
