| Version(s): | 08.11.09+ |
| Area: | Basic Settings |
| Original Author: | Kevin McDonald, Bentley Technical Support Group |
Problem:
When opening InRoads, GEOPAK, or MX (including PowerInRoads, and PowerGEOPAK) the Message Center records several "Replaced missing TrueType font..." warning messages.
Full text of warning messages included below Solution.
It was found that 2 DGNLIB files in the C:\Program Files (x86)\Bentley\MicroStation V8i (SELECTseries)\SUE "folder contained these unused fonts:
Generic Feature Definitions.dgnlib
sue.dgnlib
To resolve the warning messages, open the DGNLIB file and key-in the following command: delete unused fonts.
You can also replace these two files with the files located here: https://communities.bentley.com/products/road___site_design/m/road_and_site_design_gallery/270140/download.aspx
Display completeReplaced missing TrueType font [Yu Mincho Light] with [Arial].
Replaced missing TrueType font [Yu Mincho Light] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.
Replaced missing TrueType font [Yu Mincho Demibold] with [Arial].
Replaced missing TrueType font [Yu Mincho Demibold] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.
Replaced missing TrueType font [Yu Mincho] with [Arial].
Replaced missing TrueType font [Yu Mincho] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.
Replaced missing TrueType font [Yu Gothic Light] with [Arial].
Replaced missing TrueType font [Yu Gothic Light] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.
Replaced missing TrueType font [Yu Gothic] with [Arial].
Replaced missing TrueType font [Yu Gothic] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.
Replaced missing TrueType font [Urdu Typesetting] with [Arial].
Replaced missing TrueType font [Urdu Typesetting] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.
Replaced missing TrueType font [Sitka Text] with [Arial].
Replaced missing TrueType font [Sitka Text] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.
Replaced missing TrueType font [Sitka Subheading] with [Arial].
Replaced missing TrueType font [Sitka Subheading] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.
Replaced missing TrueType font [Sitka Small] with [Arial].
Replaced missing TrueType font [Sitka Small] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.
Replaced missing TrueType font [Sitka Heading] with [Arial].
Replaced missing TrueType font [Sitka Heading] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.
Replaced missing TrueType font [Sitka Display] with [Arial].
Replaced missing TrueType font [Sitka Display] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.
Replaced missing TrueType font [Sitka Banner] with [Arial].
Replaced missing TrueType font [Sitka Banner] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.
Replaced missing TrueType font [Segoe WP SemiLight] with [Arial].
Replaced missing TrueType font [Segoe WP SemiLight] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.
Replaced missing TrueType font [Segoe WP Semibold] with [Arial].
Replaced missing TrueType font [Segoe WP Semibold] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.
Replaced missing TrueType font [Segoe WP Light] with [Arial].
Replaced missing TrueType font [Segoe WP Light] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.
Replaced missing TrueType font [Segoe WP Black] with [Arial].
Replaced missing TrueType font [Segoe WP Black] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.
Replaced missing TrueType font [Segoe WP] with [Arial].
Replaced missing TrueType font [Segoe WP] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.
Replaced missing TrueType font [Segoe UI Emoji] with [Arial].
Replaced missing TrueType font [Segoe UI Emoji] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.
Replaced missing TrueType font [Segoe UI Black] with [Arial].
Replaced missing TrueType font [Segoe UI Black] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.
Replaced missing TrueType font [Nirmala UI Semilight] with [Arial].
Replaced missing TrueType font [Nirmala UI Semilight] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.
Replaced missing TrueType font [Myanmar Text] with [Arial].
Replaced missing TrueType font [Myanmar Text] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.
Replaced missing TrueType font [Microsoft YaHei UI Light] with [Arial].
Replaced missing TrueType font [Microsoft YaHei UI Light] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.
Replaced missing TrueType font [Microsoft YaHei Light] with [Arial].
Replaced missing TrueType font [Microsoft YaHei Light] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.
Replaced missing TrueType font [Microsoft NeoGothic] with [Arial].
Replaced missing TrueType font [Microsoft NeoGothic] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.
Replaced missing TrueType font [Microsoft MHei] with [Arial].
Replaced missing TrueType font [Microsoft MHei] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.
Replaced missing TrueType font [Microsoft JhengHei UI Light] with [Arial].
Replaced missing TrueType font [Microsoft JhengHei UI Light] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.
Replaced missing TrueType font [Microsoft JhengHei Light] with [Arial].
Replaced missing TrueType font [Microsoft JhengHei Light] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.
Replaced missing TrueType font [Leelawadee UI Semilight] with [Arial].
Replaced missing TrueType font [Leelawadee UI Semilight] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.
Replaced missing TrueType font [Leelawadee UI] with [Arial].
Replaced missing TrueType font [Leelawadee UI] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.
Replaced missing TrueType font [Javanese Text] with [Arial].
Replaced missing TrueType font [Javanese Text] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.
Replaced missing TrueType font [DengXian] with [Arial].
Replaced missing TrueType font [DengXian] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.
Replaced missing TrueType font [Aldhabi] with [Arial].
Replaced missing TrueType font [Aldhabi] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.
Replaced missing TrueType font [@Yu Mincho Light] with [Arial].
Replaced missing TrueType font [@Yu Mincho Light] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.
Replaced missing TrueType font [@Yu Mincho Demibold] with [Arial].
Replaced missing TrueType font [@Yu Mincho Demibold] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.
Replaced missing TrueType font [@Yu Mincho] with [Arial].
Replaced missing TrueType font [@Yu Mincho] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.
Replaced missing TrueType font [@Yu Gothic Light] with [Arial].
Replaced missing TrueType font [@Yu Gothic Light] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.
Replaced missing TrueType font [@Yu Gothic] with [Arial].
Replaced missing TrueType font [@Yu Gothic] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.
Replaced missing TrueType font [@Microsoft YaHei UI Light] with [Arial].
Replaced missing TrueType font [@Microsoft YaHei UI Light] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.
Replaced missing TrueType font [@Microsoft YaHei Light] with [Arial].
Replaced missing TrueType font [@Microsoft YaHei Light] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.
Replaced missing TrueType font [@Microsoft NeoGothic] with [Arial].
Replaced missing TrueType font [@Microsoft NeoGothic] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.
Replaced missing TrueType font [@Microsoft MHei] with [Arial].
Replaced missing TrueType font [@Microsoft MHei] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.
Replaced missing TrueType font [@Microsoft JhengHei UI Light] with [Arial].
Replaced missing TrueType font [@Microsoft JhengHei UI Light] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.
Replaced missing TrueType font [@Microsoft JhengHei Light] with [Arial].
Replaced missing TrueType font [@Microsoft JhengHei Light] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.
Replaced missing TrueType font [@DengXian] with [Arial].
Replaced missing TrueType font [@DengXian] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.
Replaced missing TrueType font [SketchFlow Print] with [Arial].
Replaced missing TrueType font [SketchFlow Print] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.
Replaced missing TrueType font [Segoe UI Semilight] with [Arial].
Replaced missing TrueType font [Segoe UI Semilight] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.
Replaced missing TrueType font [Segoe Marker] with [Arial].
Replaced missing TrueType font [Segoe Marker] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.
Replaced missing TrueType font [Segoe Condensed] with [Arial].
Replaced missing TrueType font [Segoe Condensed] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.
Replaced missing TrueType font [Nirmala UI] with [Arial].
Replaced missing TrueType font [Nirmala UI] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.
