| Product(s): | Bentley i-model Composition Server (iCS) | ||
| Version(s): | 08.11.11.xx | ||
| Area: | General | ||
| Subarea: | N\A | ||
| Original Author: | Dawn Gentry, Bentley Technical Support Group | ||
The iCS server has been moved to a different server. Users in ProjectWise Explorer are submitting renditions using right-click on the document and selecting Create Rendition. They are still seeing the old server. How can I make the users see the new server name?
On the ProjectWise Integration Server, modify the dmskrnl.cfg on the to point to the new iCS server. Also make sure the new server is in the trusted servers section. See below.
Edit the dmskrnl.cfg file (C:\Program Files\Bentley\ProjectWise\bin\dmskrnl.cfg)
