| | Applies To | | |
| | Product(s): | ProjectWise InterPlot Organizer | |
| | Version(s): | System.Data.DataRowView | |
| | Environment: | N\A | |
| | Area: | General | |
| | Subarea: | N\A | |
| | Original Author: | Frank Reimann, Bentley Technical Support Group | |
A PDF files includes yellow “phantom lines”, which are not part of the design file. This PDF file was created using MicroStation V8i (SELECTserie 2), ProjectWise InterPlot Professional (SELECTseries 2) Version 08.11.07.126 and a Design Script, which sets the areas to transparent. The problem does not occur without using the design.
The problem was solved after upgrading to ProjectWise InterPlot Professional Version V8i (SELECTseries 4) 08.11.11.34 .
