| Product(s): | ProjectWise InterPlot Organizer | ||
| Version(s): | 08.11.11.56 | ||
| Area: | General | ||
| Subarea: | N\A | ||
| Original Author: | Mark Marrero, Bentley Technical Support Group | ||
I want to change the Author setting within pdfs crested from PW Interplot Organizer? Currentley when you create a pdf and check the files Author attributes it reads as Bentley Systems Incorporated.
