| Version(s): | 08.11.09+ |
| Area: | Terrain Model |
| Original Author: | Jacquelyn Pettus, Bentley Technical Support Group |
Question:
How do I define the default directory where the Wizard Setting files (*.TIW) for the Create Terrain From ASCII tool are located?
Answer:
You will need to define a new configuration variable to set the default directory for the TIW files. This variable is:
CIVIL_TM_USERTIW_FOLDER
