| Product(s): | Bentley i-model Composition Server | ||
| Version(s): | 08.11.11.590 | ||
| Area: | |||
| Subarea: | N\A |
When I try to create renditions of specific files and I have "Display descriptions" enabled in ProjectWise I get the following error in my email notification:
Summary for Job
Job Status
The following error occurred on YEPEE0242HSVVM2: Could not locate ProjectWise document "pw://yepee0242hsvvm2.bentley.com:Ed&space;DCS/Documents/Deliverables&space;-&space;374263/PHASE-4&space;HYDRAULIC&space;PROFILE". Please create it or check its access permissions. - Failed to compile a moniker from given string. - Detail: Not found. - ProjectWise error ID 50000
Run Time
00:00:00
Documents in Job
0
The error messages were caused by having a space character at the beginning of the "Description" field. Once removed the rendition generated correctly.
| Original Author: | Ed Yepes |
