| | Product(s): | ProjectWise InterPlot Organizer | |
| | Version(s): | 08.11.11.56 | |
| | Environment: | N\A | |
| | Area: | General | |
| | Subarea: | N\A | |
The created PDF file from a word document, which contains raster images, is very large, when the PDF Creator Application is Ghostscript instead of the recommended application Adobe Acrobat.
Ghostscript allows some PDF creation settings that can reduce the size of the PDF file.
Using Ghostscript 9.16, it was possible to reduce the files size by 80% using the settings
dPDFSETTINGS=/ebook.
You can edit the Ghostscript options in the ProjectWise InterPlot Organizer Configuration – Integration dialog box
PDF Creator Application (gs916w32.exe) :
C:\Program Files (x86)\gs\gs9.16\bin\gswin32c.exe
PDF Creator Application Arguments:
-q -dSAFER -dNOPAUSE -dBATCH -sDEVICE=pdfwrite -dMaxInlineImageSize=0 -dPDFSETTINGS=/ebook -sOutputFile=
You can find more information about Ghostscript option at this website
| | Original Author: | Frank Reimann | |
