| Product(s): | Bentley i-model Composition Server | ||
| Version(s): | 10.00.00.20 | ||
| Area: | |||
| Subarea: | N\A |
When I try to create a PDF I get the following error message - this is the same from both ProjectWise Explorer and also when setting up a job in iCS Administrator.
Failed - Failed to add plot on SERVERNAME for document "\\SERVERNAME\iCS_Work\\1\191_1|\filename':
CMDERR, executed ipmstnsrvn, which failed
Had user set the variable IP_DCS_RENDITION_PRINTER in the ip.cfg file on the iCS server to a valid printer
| Original Author: | Ed Yepes |
