| Product(s): | Bentley i-model Composition Server for PDF | ||
| Version(s): | |||
| Environment: | Windows Server 2008 R2 | ||
| Area: | |||
| Subarea: | |||
| Original Author: | Todd Combs, Bentley Technical Support Group | ||
When an interactive job is submitted from ProjectWise Explorer, the job is created in iCS Administrator but does not run. The job can be started manually and a rendition is published.
The problem was caused by a corrupt Orchestration Framework database. The database was recreated to resolve the problem.
