h1>
| Product(s): | Bentley i-model Composition Server for PDF | ||
| Version(s): | |||
| Environment: | Windows Server 2008 R2 | ||
| Area: | |||
| Subarea: | |||
| Original Author: | Todd Combs, Bentley Technical Support Group | ||
When attempting to create a rendition from ProjectWise Explorer the following error display:
Error calling the rendition web service.
- System.ServiceModel.ServerTooBusyException: The HTTP service located at http://...../RenditionService/RenditionService.svc is too busy. - System.Net.WebException: The remote server returned an error: (503) Server Unavailable.
In IIS Manager > Application Pools, make sure RenditionServiceAppPool is Started. If it is, check the Identity credentials. Confirm the password has not expired.
