| Version(s): | 08.11.09+ |
| Area: | General Geometry |
| Original Author: | Jacquelyn Pettus, Bentley Technical Support Group |
Question:
I am attempting to import geometry into OpenRoads using the Import Geometry tool. However, one of the vertical alignments is imported but is not ruled. Why is this alignment not ruled when others are?
Answer:
If any of the following conditions are true, the imported geometry will not be ruled:
If the following is true then a "too many elements" message is produced:
If the following are true then a "too complex message" is produced:
