A partire da ottobre 2018, tutte le nuove release dei prodotti Bentley CONNECT Edition utilizzeranno CONNECT Licensing anziché SELECTserver. Verranno perciò attivati attraverso il login Bentley e non tramite la chiave di attivazione del sito. Di seguito la lista con la prima versione di ogni prodotto a utilizzare CONNECT Licensing.
| Nome | Versione |
| AECOsim Building Designer | 10.04.00.69 |
| AutoPIPE | 12.00.00.14 |
| AutoPIPE Advanced | 12.00.00.14 |
| AutoPIPE Nozzle | 12.01.00.10 |
| AutoPIPE Nuclear | 12.00.00.14 |
| AutoPIPE Vessel | 41.00.00.06 |
| AutoPIPE Vessel Code British | 41.00.00.06 |
| AutoPIPE Vessel Code Euro | 41.00.00.06 |
| AutoPIPE Vessel Code French | 41.00.00.06 |
| AutoPIPE Vessel Code German | 41.00.00.06 |
| AutoPIPE Vessel Code Russian | 41.00.00.06 |
| AutoPIPE Vessel Code USA | 41.00.00.06 |
| AutoPIPE Vessel Enterprise | 41.00.00.06 |
| AutoPLANT Modeler CONNECT Edition | 10.00.00.36 |
| Bentley CulvertMaster CONNECT Edition | 10.03.00.03 |
| Bentley Descartes | 10.04.00.25 |
| Bentley Descartes for MicroStation | 08.11.09.905 |
| Bentley Facilities Space Planner | 10.02.00.23 |
| Bentley FlowMaster CONNECT Edition | 10.02.00.01 |
| Bentley GEOPAK Civil Engineering Suite (SELECTseries 10) | 08.11.09.918 |
| Bentley GEOPAK Road (SELECTseries 10) | 08.11.09.918 |
| Bentley LumenRT | 16.11.05.50 |
| Bentley Map (OpenCities Map) | 10.02.00.18 |
| Bentley Map Enterprise (OpenCities Map Enterprise) | 10.02.00.18 |
| Bentley Map PowerView (OpenCities Map PowerView) | 10.02.00.18 |
| Bentley OpenPlant 2D iModel Bridge | 10.01.00.36 |
| Bentley OpenUtilities Analysis | 10.02.00.05 |
| Bentley OpenUtilities Designer | 10.03.00.04 |
| Bentley OpenUtilities sisNET CONNECT Edition | 10.04.00.08 |
| Bentley Pointools | 10.01.00.01 |
| Bentley Rail Track | 08.11.09.918 |
| Bentley Rail Track Suite | 08.11.09.918 |
| Bentley Raceway and Cable Management | 10.00.00.127 |
| Bentley Speedikon | 10.00.00.25 |
| Bentley View | 10.11.00.41 |
| CNCCBIM OpenRoads | 10.06.01.09 |
| ContextCapture | 04.04.11.60 |
| ContextCapture Center (Engine) | 04.04.11.60 |
| ContextCapture Center (Master) | 04.04.11.60 |
| ContextCapture Editor | 10.03.00.23 |
| ContextCapture Viewer | 04.04.11.60 |
| gINT Civil Tools Professional Plus | 10.03.00.13 |
| gINT Logs | 10.00.01.07 |
| gINT Professional | 10.00.01.07 |
| gINT Professional Plus | 10.00.01.07 |
| HoleBASE Civil 3D 2018 CONNECT Edition | 02.22.02.72 |
| HoleBASE Civil 3D 2019 CONNECT Edition | 02.22.02.72 |
| HoleBASE CONNECT Edition (Data Entry, Standard, Professional) | 01.34.02.86 |
| HoleBASE Microsoft Excel CONNECT Edition | 01.22.02.21 |
| HoleBASE Template Studio CONNECT Edition | 01.20.02.23 |
| iModel Bridge for PDMx | 10.03.00.06 |
| InRoads V8i | 08.11.09.918 |
| InRoads Suite V8i | 08.11.09.918 |
| ISM Revit Plug-in | 11.00.00.05 |
| Japan KHK2 Code for AutoPIPE | 12.00.00.14 |
| KeyLAB CONNECT Edition | 02.07.00.94 |
| LEAP Bridge Concrete | 18.02.00.12 |
| LEAP Bridge Steel | 18.02.00.12 |
| LEGION Model Builder | 01.06.05.03 |
| LEGION Simulator | 01.06.05.03 |
| MAXSURF | 22.00.00.97 |
| MAXSURF Advanced | 22.00.00.97 |
| MAXSURF Enterprise | 22.00.00.97 |
| MAXSURF Modeler Advanced | 22.00.00.97 |
| MAXSURF Stability Advanced | 22.00.00.97 |
| MAXSURF Stability Enterprise | 22.00.00.97 |
| Microstran | 10.00.00.14 |
| Microstran.Advanced | 10.00.00.14 |
| Microstran.Pro | 10.00.00.14 |
| MicroStation CONNECT Edition (Update 11) | 10.11.00.36 |
| MicroStation V8i (SELECTseries 10) | 08.11.09.908 |
| MicroStation PowerDraft CONNECT Edition (Update 11) | 10.11.00.36 |
| MicroStation PowerDraft V8i (SELECTseries 10) | 08.11.09.912 |
| MOSES | 11.00.00.97 |
| MOSES Advanced | 11.00.00.97 |
| MOSES Enterprise | 11.00.00.97 |
| Multiframe | 22.00.00.97 |
| Multiframe Advanced | 22.00.00.97 |
| OpenBridge Designer | 10.06.00.22 |
| OpenBridge Designer CCK | 10.06.00.34 |
| OpenBridge Modeler | 10.06.00.41 |
| OpenBuildings Designer (formerly AECOsim Building Designer) | 10.04.00.69 |
| OpenBuildings Station Designer | 10.05.00.19 |
| Opencities Map CONNECT Edition (Update 2) | 10.02.00.18 |
| Opencities Map V8i (SELECTseries 10) | 08.11.09.908 |
| Opencities Map Enterprise CONNECT Edition (Update 2) | 10.02.00.18 |
| Opencities Map Enterprise V8i (SELECTseries 10) | 08.11.09.908 |
| OpenCities Map PowerView CONNECT Edition (Update 2) | 10.02.00.18 |
| OpenCities Map PowerView V8i (SELECTseries 10) | 08.11.09.922 |
| OpenFlows CivilStorm | 10.02.00.55 |
| OpenFlows FLOOD | 10.00.02.01 |
| OpenFlows FlowMaster | 10.02.00.01 |
| OpenFlows HAMMER | 10.02.00.43 |
| OpenFlows PondPack | 10.02.00.01 |
| OpenFlows SewerCAD | 10.02.00.55 |
| OpenFlows SewerGEMS | 10.02.00.55 |
| OpenFlows StormCAD | 10.02.00.55 |
| OpenFlows WaterCAD | 10.02.00.43 |
| OpenFlows WaterGEMS | 10.02.00.43 |
| OpenPlant Isometrics Manager | 10.02.00.36 |
| OpenPlant Modeler | 10.02.00.37 |
| OpenPlant Orthographics Manager | 10.02.00.36 |
| OpenPlant PID | 10.02.00.36 |
| OpenPlant Project Administrator | 10.02.00.36 |
| OpenPlant Support Engineering | 10.02.00.36 |
| OpenRail ConceptStation | 10.00.09.20 |
| OpenRail Designer | 10.06.00.38 |
| OpenRoads ConceptStation | 10.00.09.20 |
| OpenRoads Designer | 10.06.00.38 |
| OpenRoads SignCAD | 10.00.00.12 |
| OpenRoads SignCAD Viewer | 10.00.00.12 |
| OpenSite Designer | 10.07.00.56 |
| OpenTower Comms Visa (formerly STAAD Tower Comms Visa) | 10.00.02.00 |
| OpenUtilities Design Optioneering | 10.03.00.07 |
| OpenUtilities Substation (formerly Bentley Substation) | 10.02.00.25 |
| Plant Exporter | 10.03.00.06 |
| PLAXIS 2D CONNECT Edition | 20.00.00.119 |
| PLAXIS 3D CONNECT Edition | 20.00.00.119 |
| PowerCivil for Countries V8i | 08.11.09.917 |
| Power GEOPAK V8i | 08.11.09.918 |
| Power InRoads V8i | 08.11.09.918 |
| Power Rail Track | 08.11.09.918 |
| PowerSurvey | 08.11.09.918 |
| ProjectWise Interplot Organizer CONNECT Edition | 10.00.02.29 |
| ProjectWise Interplot Server CONNECT Edition | 10.00.02.29 |
| Promis.e | 10.00.00.49 |
| ProStructures (Update 2) | 10.02.00.20 |
| RAM Concept | 07.00.00.12 |
| RAM Concept Post Tension | 07.00.00.12 |
| RAM Concrete | 16.00.00.28 |
| RAM Connection | 13.00.00.56 |
| RAM Elements | 16.00.00.37 |
| RAM Foundation | 16.00.00.28 |
| RAM Frame Analysis | 16.00.00.28 |
| RAM Frame Steel Design | 16.00.00.28 |
| RAM Modeler | 16.00.00.28 |
| RAM Steel | 16.00.00.28 |
| RAM Structural System | 17.00.00.93 |
| RM Bridge | 11.04.00.17 |
| RM Bridge Advanced | 11.04.00.17 |
| RM Bridge Enterprise | 11.04.00.17 |
| SACS Collapse | 13.00.00.01 |
| SACS Fatigue | 13.00.00.01 |
| SACS Fatigue Advanced - Dynamic Response | 13.00.00.01 |
| SACS Fatigue Advanced - Wave Response | 13.00.00.01 |
| SACS Fatigue Enterprise | 13.00.00.01 |
| SACS Marine | 13.00.00.01 |
| SACS Marine Advanced | 13.00.00.01 |
| SACS Offshore Structure | 13.00.00.01 |
| SACS Offshore Structure Advanced | 13.00.00.01 |
| SACS Offshore Structure Enterprise | 13.00.00.01 |
| SACS Pile Structure Design | 13.00.00.01 |
| SACS Wind Turbine | 13.00.00.01 |
| SOILVISION CONNECT Edition | 10.00.00.13 |
| STAAD Advanced Concrete Design RCDC | 08.00.00.16 |
| STAAD.Pro CONNECT Edition | 22.00.00.15 |
| STAAD.Pro Advanced CONNECT Edition | 22.00.00.15 |
| STAAD Foundation Advanced | 09.00.00.09 |
| STAAD RCDC FE | 03.00.00.11 |
| Structural Enterprise | * |
| Substation China | 10.03.00.16 |
| SYNCHRO OpenViewer | 06.01.01.01 |
| SYNCHRO Pro | 06.01.01.01 |
| SYNCHRO Pro - Iray Add-on | 06.01.01.01 |
| SYNCHRO Scheduler | 06.01.01.01 |
* Il pacchetto Structural Enterprise License funziona con CONNECT Licensing, a condizione che tutte le versioni dei singoli prodotti utilizzati siano su CONNECT Licensing.
Articolo originale in inglese
