| Product(s): | ProjectWise InterPlot Organizer | ||
| Version(s): | 10.00.00.64 | ||
| Environment: | Windows 10 | ||
| Area: | IPLOT | ||
| Subarea: | N\A | ||
| Defect Number: | 877065 |
After Windows 10 update to Spring Creator 2018 (build 1803), MicroStation will hang or crash when InterPlot is integrated with MicroStation CONNECT Edition Update 5 or higher
Upgrade your Windows 10 to Spring Creator 2018 (build 1803) and integrate MicroStation with InterPlot Organizer 10.00.00.64 or ealier
Don't integrate InterPlot Organizer with MicroStation CONNECT and contact Bentley Plotting Technical support to receive the 10.00.00.70 version of ProjectWise InterPlot Organizer which corrects the issue.
https://bentleysystems.service-now.com/community?id=kb_article_view&sysparm_article=KB0110936
Other Languages:
