Product(s): | ProjectWise InterPlot Organizer | ||
Version(s): | 08.11.11.56 | ||
Environment: | Windows 7 64 bit | ||
Area: | Installation | ||
Subarea: | N\A |
When I attempt to install Projectwise Interplot Organizer SS4, the following error appears even though the Prerequisite Pack in question is already installed: "This product requires at least version 08.11.09.03 for Bentley Desktop Applications: Please install the latest version of this package and then restart this installation."
Note: The issue is that if there is any subkey that does not follow the proper naming convention (i.e. 081109xx, 081107xx. 080904xx), the Organizer install will fail the desktop prerequisite check.
