Recursive Folder Input
When adding a folder to a job input set, it is now possible with Bentley iCS for PDF CONNECT Edition Update 3.2 to specify recursive inclusion of child folders. Previously only documents residing directly within the folder specified were processed.
This control is available only for folder input set items, not document or saved search items.
By default, folders added to the input set continue to exclude child folders.
