New with Bentley iCS for PDF CONNECT Edition Update 3.2, the ProjectWise Administrator rendition profile ‘Output Destination Folders’ component now contains an option to copy the environment from the source folder when creating folders in the destination data source. The behavior of <copy from source folder> is similar to that of the same option under ‘Workflow’. If distributing to a different data source, a environment with the same name as the source environment must exist, otherwise the new folder inherits its parent folder’s environment.
This setting is useful for source distribution jobs where references, especially border files, do not share the same environment as the master documents, distributing all files into a single destination environment cannot be performed due to missing document code component values, and creating in advance all the necessary destination folders with the appropriate environments is impractical.
