Error Message: The assembly [varies] is not trusted due to SubjectCertExpired
Summary:
You may encounter errors when using I-Model Composition Server (ICS) Administrator after June 10, 2021.
Background:  As a part of a continuing program to improve the security and integrity of Bentley software and services, over the last several releases, the ICS product added several security validation checks on program modules (.DLL files) that are loaded into memory.  Some of these validation checks were more stringent than intended. As a result, some legitimate and safe DLLs included with the product began to be rejected after June 10, 2021.
The following provides the solution based on the Version of ICS you are running.
Problem:
Resolution:
No resolution required.  We do not know of any issues with this software version.
Problem:
 Resolution:
[HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Bentley\Orchestration Framework\Server],
"IgnoreCertExpiration"=dword:00000001
[HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Bentley\Orchestration Framework\Administrator]
Problem:
 Resolution:
"ValidateCertificateChains"=dword:00000000
“ValidateCertificateChains"=dword:00000000
