| Version(s): | 08.11.09+ |
| Area: | Civil Cells |
| Original Author: | Sanders Thomas, Bentley Technical Support Group |
Problem:
Civil Cells are not being placed at the correct elevation when placed at a T-intersection.
Ensure that when the Civil Cell is placed the user does not use the “Nearest” Snap. Have user select end point, intersection, perpendicular, tangent or center snaps instead.
