| Product(s): | ProjectWise Dynamic Composition Server | ||
| Environment: | Window Server 2008 64 bit, Windows 7 64 bit, Windows Server 2008 R2 | ||
| Area: | |||
| Original Author: | Steve Boniwell, Bentley Technical Support Group |
When running an i-model Composition job from either ProjectWise Explorer or i-model Composition Server Administrator, an error message "Network Path Not Found" is displayed and the job is not processed.
The working directory that is set for i-model Composition Server is not accessible.
Ensure that the Working Directory specified is accessible.
