| Version(s): | 08.11.09+ |
| Area: | Survey |
Question:
Is it possible to add a suffix or prefix to multiple points at one time within the Survey Details window?
Answer:
Yes, you can add prefixes and suffixes to point names by using the details panel while viewing points in the panel. Select the points that you wish to edit, right mouse click to invoke “Edit selected items”. In the edit field enter the prefix that you wish to use followed by a PLUS sign (+) to prepend, or enter the PLUS sign (+) followed by the text to append the point name.
