| Product(s): | InRoads |
| Version(s): | 08.11.07+ |
| Area: | Drainage |
| Original Author: | Jacquelyn Pettus, Bentley Technical Support Group |
Question:
Where can you edit the structures.dat file as needed to meet specific design criteria?
Answer:
The structures file (*.dat) should be edited within the InRoads product. To make changes, go to Tools>Drainage>Structures from within the InRoads Explorer menu. This command allows you to add and modify parameters in your drainage structures file – an ASCII file that contains standards (sizes, shapes, materials, and other parameters) for your drainage structures.
