| Product(s): | Digital InterPlot | ||
| Version(s): | InterPlot Client, InterPlot Professional 9.x, 10.x | ||
| Area: | N/A | ||
| Subarea: | N/A | ||
InterPlot Organizer is a Windows application for plotting MicroStation design files, AutoCAD drawing files, raster files and Digital Print Room files.
InterPlot Organizer allows you to work on a group of plots as a single plot set and gives you full control over plot sets and the plots they contain. You can add, delete and rearrange plots; view and modify the properties of individual or multiple plots; and preview and print all or some of the plots. You can also control how information about the plots in a set is displayed in the Organizer main window.
Using Organizer, you can plot sets of MicroStation design files, AutoCAD drawing files, raster files or Digital Print Room files without saving or reusing the plot sets. You can also create a plot set for a particular set of files to be replotted periodically.
InterPlot Organizer offers you several advantages:
To start Organizer, do one of the following:
iplotorg.exe <plot_set_filename>If you started Organizer without specifying a plot set, a Welcome dialog box appears.
The Welcome dialog box contains shortcuts for the two operations that load information into Organizer: creating new plot sets from files you select and opening an existing plot set.
Select the appropriate option from the Welcome to InterPlot Organizer dialog box and click OK. Click Cancel to exit the Welcome dialog box without performing any operation. Note: If you prefer that this dialog box not be displayed the next time you run InterPlot Organizer, click the "Don't display this screen again" option before clicking OK.
For additional information about Organizer, click Help Topics from within Organizer.
InterPlot Client/Professional includes an Organizer command line interface that runs from the command prompt. You can use the command line interface to create, modify, preview, print and archive plot sets, and to export plots from plot sets. Plot sets can be composed of MicroStation, AutoCAD, raster, and Digital Print Room data.
The Organizer command line provides the following commands:
| Create | Creates plot set files |
| Modify | Modifies plot set files |
| Export | Exports plots from a plot set file as PARM files |
| Preview | Displays plots on the screen before printing |
| Prints a plot set | |
| Archive | Archives a plot set file without printing |
An Organizer command line has the following syntax:
iplotorg <command> <-qualifiers> plotset_file
For additional information on the Organizer command line interface, please refer to InterPlot Reference Help.
ProjectWise TechNotes And FAQs
