Installing InRoads (08.07.00.82) with MicroStation(08.05.02.35) launch Error:
"Error loading the LOCALE resources library, CIVUSTNZF.DRX"
followed by a lot of similar messages:
1. Search directory C:\Program Files\Bentley\InRoads Group\bin \3082
2. Rename folder 3082 manually as 1033
3. Run the program again and Issue should be resolved
