| Product(s): | InRoads |
| Version(s): | 08.11.07+, 08.11.09+ |
| Area: | Drafting |
| Original Author: | Jacquelyn Pettus, Bentley Technical Support Group |
Problem:
I am attempting to use Place Plan Note to annotate the Structure ID and Invert Elevation of my drainage pipes. However, it is not working as shown below:
In order for these items to properly annotate, make sure that the Placement Mode is set to "Element" on the Settings tab of the command.
