| Product(s): | ProjectWise XM | ||
| Original Author: | Stephen Herrick, Bentley Technical Support Group |
Distribution Services - Failed to created Rendition. User receives error Failed - Failed to create plot set: ProjectWise Error - PWISE, ProjectWise API Error. ProjectWise API Error Detail:
The user had created a Job using Distribution Admin., that Job was set to create a rendition and place it in the ProjectWise Storage area. which was failing to run
The distribution share folder had a space in the name, and a new NULL print queue was created. After setting both of those the job ran fine.
Also verify, before trouble shooting distribution service, that the same file can be Archived using ProjectWise Organizer on the Distribution Server.
