Cut and Fill Values and Graphics do not display when running the Open Cross Section View command
Product(s):InRoads
Version(s):08.11.09+
Area: Cross Section
Original Author:Kevin McDonald, Bentley Technical Support Group
Problem:
I cut dynamic sections using the Open CrossSection Views command, and when I select View Properties to turn on Display Cut and Fill Graphics or Display Cut and Fill Values, they do not display
There are 2 things that will allow the cut/fill graphics and cut/fill values to show up in the cross section views:
1.)    Verify the existing ground is set as the Active terrain
2.)    Run the Process Corridor command before creating the sections.
