| Product(s): | Bentley i-model Composition Server | ||
| Version(s): | 8.11.13.62 | ||
| Area: | Administrator | ||
| Subarea: | N\A | ||
| Original Author: | Dawn Gentry, Bentley Technical Support Group | ||
Can iCS for PDF and iCS for i-model (Bentley Automation Services) co-exist on the same server?
Though both iCS for PDF and i-models can co-exist on the same machine, it is generally not recommended for production given the CPU intense process that both formats require.
