| Product(s): | ProjectWise InterPlot Driver Pack | ||
| Version(s): | N/A | ||
| Area: | General | ||
| Subarea: | |||
| Original Author: | Frank Reimann, Bentley Technical Support Group | ||
Is it possible to update an existing ProjectWise InterPlot Driver Pack with a newer version without removing the older version, because all InterPlot print queues must be re-created if a driver pack is removed from the Server?
If it is not a Major Release upgrade (example: ProjectWise XM to ProjectWise V8i ) than you can install the newer ProjectWise InterPlot Driver Pack versions on top of the existing older ProjectWise InterPlot Driver Pack.
Example
ProjectWise InterPlot Driver Pack Version 03.04.03.11
Update to
ProjectWise InterPlot Driver Pack Version 03.04.04.62
Example 2
ProjectWise InterPlot Mid-Volume Driver Pack Version 01.04.01.29
Update to
ProjectWise InterPlot Mid-Volume Driver Pack Version 01.04.04.60.
If it is a Major Release upgrade, then you have to remove the ProjectWise Driver Packs, Reboot and install it from scratch. Make sure that you have all printer queue settings documented.
