| Product(s): | PROJECTWISE INTERPLOT DRIVER PACK | ||
| Version(s): | 02.01.00.12 | ||
| Area: | IPLOT | ||
| Subarea: | N\A | ||
What is the Batch Port Monitor utility?
KB: The Batch Port Monitor utility is delivered with the InterPlot Raster Offline Driver Pack. The utility allows offline files to
be automatically written to a specified directory using a defined naming convention, without having to key in a directory location or filename at plot time - saving valuable time in the batch plotting workflow.
