| Product(s): | ProjectWise InterPlot Driver Pack | ||
| Version(s): | 03.04.04.62 | ||
| Area: | General | ||
| Subarea: | |||
| Original Author: | Ed Yepes, Bentley Technical Support Group | ||
We have an OCE PlotWave 300 plotter that we use with IPLOT. Our ProjectWise Interplot Driver Pack is version 03.04.04.62.
We are using the Bentley drivers from this driver pack for our plotting and need to know what is the maximum length that we can plot a continuous plot on this plotter?
Per Oce the maximum continuous plot length is 15 Meters or about 590 inches. Anything after that will most likely be skewed therefore quality/accuracy cannot be expected.
