| Version(s): | 08.11.09.674 |
| Area: | Corridor Modeling |
| Original Author: | Kevin McDonald, Bentley Technical Support Group |
Question:
When running the Import IRD command, it is import that all corridor dependencies such as the Target Aliases and targeted corridors already be present in the model. Is there a report I can run to show the dependencies of the corridors contained in the IRD file so that I know what order I should import my data?
Answer:
The "CorridorDependencyReport.xsl" report will show all Point Controls, Target Aliases, and Clipping options used by the corridors in the IRD.
To use:
Download the following XSL file: CorridorDependencyReport.xsl
Place the file in the "C:\ProgramData\Bentley\Civil\ReportBrowser\8.11.9\en\CorridorModeling" folder.
Open the Bentley Civil Report Browser and us the File>Open (*.IRD) to open the IRD file to be imported.
Select the "CorridorDependencyReport.xsl".
