| Product(s): | PROJECTWISE INTERPLOT DRIVER PACK | ||
| Version(s): | 03.00.00.00 | ||
| Area: | IPLOT | ||
| Subarea: | N\A | ||
IP Need to plot white--When defining color = (255,255,255) in an IPLOT pentable line work are plotting black. Area fills are plotting white as desired.
Make sure Rendering Mode in the Rendering Attributes are set to Full Color.
