| Product(s): | PROJECTWISE INTERPLOT DRIVER PACK | ||
| Version(s): | N\A | ||
| Area: | IPLOT | ||
| Subarea: | N\A | ||
| Original Author: | Beverly Dawn Gentry, Bentley Technical Support Group | ||
When viewing cals files created from ProjectWise InterPlot Organizer and the ProjectWise Raster Offline Driver Pack, the files are always rotated in the cals viewer. The output is correct. Why is this?
Basically, when we create the cals file from InterPlot, we create it for printing and use Landscape as the orientation. All of the cals viewers will use Portrait as the orientation because you are viewing on the screen. We do not have a way to control this in the creation of the output. You viewer may possibly have an option to view in Landscape orientation.
