| Product(s): | ProjectWise InterPlot Mid-Volume Driver Pack | ||
| Version(s): | 03.04.01.32 | ||
| Area: | Windows 2008 R2 SP1 | ||
| Subarea: | |||
| Original Author: | Evert de Jong, Bentley Technical Support Group | ||
How to configure Folding Output with Oce ColorWave 650
Problem Description
User has installed Océ ColorWave 650 large format plotter with Océ 4311 full fold series connected.
User requests that the default finishing method is ‘Folding’ with capability to use another output option.
used printer driver is: Oce ColorWave 600 by Bentley from ProjectWise Interplot Mid-Volume Driver Pack V01.04.04.60 on Windows Server 2008 R2.
Steps to Resolve
However on plotter console is was configured that the Océ 4311 folding unit is output the following was needed on Printer driver.
1) Create a Graphical Rendering attribute file for Oce ColorWave 600 printer driver.
ProjectWise InterPlot Utilities > Graphical Attribute Editor > Open Default
-Select correct printer
Set Desposit to: Folder On (see file:GAE-ColorWave600-Desposit.PNG)
Save file as RA file.
Repeat the steps for other Desposit values as TOP DELIVERY and REAR DELIVERY
Make sure the following options are used before submitting a plot.
Rotate drawing 180 degrees and select you rendering attribute file
2) Second option is by creating a settings file for the printer by saving the contents below in a file called <printer name>.set
-Rotation=180
-Rendering_Attrbutes=<rendering attribute file.
