| Product(s): | ProjectWise InterPlot Mid-Volume Driver Pack | ||
| Version(s): | 01.04.04.60 | ||
| Environment: | Window Server 2008 64 bit | ||
| Area: | General | ||
| Subarea: | N\A |
When I submit an IPLOT job to our Oce TDS 700 plotter using the TDS 700 by Bentley driver from the Projectwise Interplot Mid-volume Driver Pack, the job submits successfully but nothing comes out on the plotter. The plot job appears to be held by the Oce controller. The job can be manually released from the controller, otherwise it remains there.
