| Product(s): | Bentley i-model Composition Server | ||
| Version(s): | 8.11.13.62 | ||
| Area: | i-model Generation | ||
| Subarea: | N\A | ||
| Original Author: | Dawn Gentry, Bentley Technical Support Group | ||
The iCS jobs will not start. They remain in the Idle state.
Possible causes are as follows:
Check the .net update. The server had .net 3.5.1 on it and had not been updated in some time. After running numerous updates we were able to get pdfs and Imodels generated from the server. Use this link to tell if your .net is up-to-date:
