| Product(s): | Bentley i-model Composition Server | ||
| Version(s): | 8.11.13.62 | ||
| Area: | i-model Generation | ||
| Subarea: | N\A | ||
| Original Author: | Dawn Gentry, Bentley Technical Support Group | ||
What data types does Bentley i-model Composer support when used as the print engine?
When using Bentley i-model Composer as the i-model publishing engine, iCS for i-models supports publishing application data coming from:
