| Product(s): | Bentley i-model Composition Server | ||
| Version(s): | 10.00.03.299 | ||
| Area: | |||
| Original Author: | Edwin Lugo, Bentley Technical Support Group | ||
When submitting a rendition users may get the following error on the submission email. This is caused because submitting user has no access to the specified folder where most likely a .set file or a pen table are stored.
Figure 1. Example of the email with the error
Figure 2. Using search builder to look for the specified folder
Figure 3. Check permissions on folder to grant access to submitting user.
Provide at least document read permissions to submitting user to be able to access the folder specified in the error
