| Product(s): | InRoads |
| Version(s): | 08.11.07+ |
| Area: | Survey |
Question:
How can I change the elevations of survey points? For example, I need to add 2 ft to all survey points.
Answer:
The command Survey>Transform Survey Data allows you to move, scale and/or rotate data from one coordinate basis (X,Y,Z) to another location based on point numbers or new coordinates. You can also rotate the data at the original point or at a new location based on a specified angle.
